New O/B Las Vegas needs help lol
I saw your sig and wrote it down if look at upper picture. That is what I thought was getting but didn't inventory it as was loading truck so ya got wrong one
Missed that pic! I was on my phone :( sorry
Where did you get it from? You will be able to use it for your daily water test once you get things up and running so it is not a total loss.
I bet you saw the numbers and thought that was it. SO close. I would have done the same thing.
Kim
Plumbing done and rebar tomorrow
Very clean very recommended. He did miss few things on prints second skimmer and miss judged distance to solar stub he said before started . Said his bid is his bid will do at no extra charge his fault. I Gave him $150 extra because of his honesty and he also bought all my pool equipment at his cost. I price matched it out and could of saved maybe a hundred if tried but awesome guy.
Guy said doesn't do to many pools on side unless referral cause so busy. Had great communication. Said since I removed infloor moved my pool to front of line cause would be easy and had payment in hand helps lol. Painted all pipes out of filters and pump to match just shows to me takes pride. Probably standard I don't know but did and labeled it all also
Ya after telling him doing Inground cleaning and pricing labor and parts. To cancelling and all that. Guy never complained came few days earlier then was scheduled and said he would do at same price. I just noticed yesterday because I went to get parts and only noticed one skimmer. I purchased a second one knowing needed 2. Soon as he got her I double checked his pricing wanting to know if missed skimmer and thought solar stubs was way cheaper then he told me it would be per foot. Told him I'm more then fair if it was more let me know. Said nope his fault. I did pay him extra because I know owning a company and he is out working not like he is rich. Just a good hard working guy wanted to be fair with. From what I heard and what he told me any problems or complaints he is there right away to fix. Man so far subs have been great.
Bummer you had to ditch the inground! I am getting to love mine more and more. We had a huge windstorm last week and pool was full of pine needles and leaves. 6 hours of the infloor running and the pool is spotless.
Leafvac was full and basket at
The pump has no debris.
FYI - it is Code to paint all exposed PVC in Clark County, NV. Due to sun degradation. The building inspector would not have passed the install if not painted.
Also - you have a tube turn immediately before your SWCG. Pentair recommends 12-18" of straight pipe before the SWCG. I had to re-pipe mine as it was also installed with a tube turn a few inches from the inlet and thus required a much higher (~2100 RPM) flow rate from my VS pump to run the SWCG. By re-piping I got the flow rate down to ~1500 RPM needed to run the SWCG. A large power savings.
Have fun! Has been over a year since our install and still working through minor issues. But great to have a pool to jump in to!
Thanks I will check into that
