So is there a return that’s off ? (You’ll have a valve to adjust/open) or is there no return and only the in floor cleaners ? (Some pools use the IFCS as the return).
With no return, still suspend the sock out into the pool. With enough time to soak it will squish out the same. Being hit by a return jet speeds it along a little but no biggie.
We do in fact.
Every last one of us was there once and remember being overwhelmed. Don’t get discouraged. Each flub cements what you read into permanent memory and even helps you connect further dots.
Like here for example. You are now well learnt to not add acid to the equipment. When the time comes for Muriatic Acid to manage your PH, you’ll instinctively know you want it added to the pool water. (Pencil sized stream, stand upwind, brush real good after as it’s heavier than water and might puddle up on the bottom).
There will be some other bumps and we got you when they happen also. Each time you level up.
