Hello all,
New to this website but loving it so far
Purchased a home over the winter and trying to get the pool up and running. I have no idea how well the previous owner cared for the pool.
Took the cover off (specs in signature) to a dark green swamp with a healthy pile of leaves at the bottom. Stuck a measuring tape in and lost sight at the 6-inch mark...it was bad.
In hindsight I probably should have just drained ajd refilled but whats done is done. After a week, 90% of the leaves are out and the water is a cloudy blue but I can see the outline of the bottom (and a small bit of leaves hiding out in the center)
Test results:
FC = 20
CC = 0
pH = less than 7.0, but color is very close so im guessing 6.8ish
TA = 20
CH = 70
CYA = 40
My two main questions are 1) Should I work on fixing pH and TA now or after slamming is complete? 2) other than continuing to slam and scooping out the big stuff and vacuuming debris is there anything else I should be doing?
Thanks in advance!
Test results:
FC = 20
CC = 0
TA = 20
CH = 70
CYA = 40
Thanks in advance!
