I’m in the “get those stairs out and clean them” camp. Also, if you can try to raise to SLAM level when you first get up, when you get home from work, and again before bed, that’s better than once daily. If anyone else in your home is on a different schedule you could teach them how to do, and maybe that would increase your doses to 4-5 times daily.
I have similar stairs. Here is what the inside of mine looked like (and my pool was crystal clear at the time). Yours are way worse, I am sure. Did you fill them with sand? The company needs to be slapped for that instruction - it’s terrible advice. I removed all sand from mine (which took forever) and drilled holes all over the sides to allow for better water flow.
