New Hayward Ozone pool owner here
mmia24
56
st louis
somehow we hit the high CYa level ground with our plaster/gunite pool. When we did pool school I was only thought to check chlorine PH alkalinity in our pool.
We recently started noticing yellow like algae and nothing would help so I took a sample to our local pool store.
It came back that our CYA levels are super high
Since then we have drained a bit added a bit like 2 times now and keep brushing
I was told not to worry about adding any chemicals to the pool until we get CYA levels lower
Welcome to TFP!!!
How are you testing your water? Do you have one of our recommended kits? Link-->Test Kits Compared
If you do, post a full set of test results..we'll help you out!
If not, order one now. Add 5ppm of liquid chlorine per day until your kit arrives. Nothing else.
When your kit arrives, post a full set of results and we'll get you going!
You Got This Good Luck Today GIF by MOODMAN
Dont follow that advice or you’ll be dealing with a swamp in short order. Get some chlorine in the water as advised above and get a test kit on order. The pool stores give out bad advice.
Welcome to TFP!!!
I do have a test kit...I also have the latest numbers from the pool stores
Thats just downright malicious by the pool store. Adding no chlorine in the summer for any period of time is guaranteed to turn your pool into a swamp. But of course they have plenty of magic pool store potions that they will sell you that costs hundreds of $. Thats much better for them than selling you $20 worth of chlorine like they should have.
Not much I can do with that. Post up when your kit arrives!
Okay here are some pics
1 is chlorine (I have basically nothing in there)
2 PH
Cya reading was 80
But we were over 110 last week so I consider that better
If you put the powder in and it does not turn pink That means no chlorine, you can move on to CC test.
You should use the round vial with 870/871. Use 10mL sample, each drop is 0.5 FC.
This is the kit I have , yeah it did not turn pink at all
