I recently decided to go to liquid chlorine for my pool, previously a salt pool, after having several problems with salt pool cells over the years. I decided to go with the new HASA Liquids Feeder. The install was super easy and it seems to be running fine, holding my chlorine level very steady for the last 4 days. I use a Sutro to monitor chemical status so I'm getting chlorine readings 3 times per day.
My question now is on the chlorine addition process. I know the tank is designed to maintain a level between the two floats. It seems to me if I add chlorine through the filler while its at its normal operating level, the tank might overflow before I add any large amount of chlorine. It would really seem to be an issue if I attempt to add 4 gallons at once as I did for initial startup. As such, I now assume I would add 1 gallon at a time. Is it expected that I would be adding 1 gallon per day or every few days? This doesn’t seem like much of an improvement over just adding the liquid chlorine directly in the pool.
What am I missing?
Any help suggestions would be appreciated.
What am I missing?
