10,000 gal round AGP
FC: 6
CC: 0.5
CYA: ≤ 20 (Added 2 lbs. last night, still dissolving)
PH: 7.5
TA: 70
Passed OCLT 5/18
Our 2 year old filter doesn't seem to be cutting it anymore. Water appears less than clear/sharp and there are silty deposits on the bottom despite vacuuming and brushing every day for the past 5 days. (I noticed similar issues at end of last season but... procrastinated.) I cleaned the cartridge this morning (for at least the 6th time in 10 days) and pressure is 4 psi with the ("creepy crawly" suction style) vacuum running. 7-8 psi is more typical for this system and I clean the cartridge at 10-12 psi.
To be fair, we're getting hammered by pollen right now -- you can see it as a powder on practically every surface. Still, this cartridge needs cleaning way too often judging by the other info here on TFP which tells me this filter is probably too small. Sq ft rating is unknown because I can't find any info on this brand/model anywhere -- same goes for the pump. When we bought the pool we were told the pump was 1.5 hp and that's all we know.
I'm getting the feeling that the pool store gave us the lowest quality equipment they could get away with, everything looks almost toyish compared to the name brands. Pump and filter are both "Simple Clean" brand, pump says White River model no. JH115DNSGG, and the filter housing says Simple Clean SC 90-HB (HB meaning "hybrid" because it is a cartridge that also contains DE).
So all that being said, is this most likely a cartridge problem or an actual filter problem? If I want to go with a bigger and better filter, how do I choose size when I have so little info about the pump's performance?
FC: 6
CC: 0.5
PH: 7.5
TA: 70
Passed OCLT 5/18
