Turbo1Ton
- Dec 26, 2019
- 1,842
- Plaster
- Pentair Intellichlor IC-40
In relation filter pressure, what is the suggested RPM that we should be checking the pressure at with a VS pump?
Shouldn't matter, just make sure you check it at the same speed each time. I set mine @ 3200RPM, which is where my IFCS runs. But I also have to make sure to note if the IFCS is on or bypassed, because it adds about 5-6 psi drop when the IFCS is engaged.
--Jeff
