- Jan 7, 2012
- 1,500
- Plaster
- Pentair Intellichlor IC-60
Getting ready for a new PB build in The Woodlands, TX. I'd love feedback, so please critique the design. Can't wait to get started!
Overview:
47' x 23' Free-form Pool (no spa)
4'-5'-4' Depth Profile
12" Shelf
2 x Benches
~21k Gallons
Pentair Equipment:
IntelliFlo Pump 011028
520 Clean & Clear Plus Filter 160332
UltraTemp Heat Pump/Chiller 460958 AquaCal Variable Speed SQ150VS Heat Pump/Chiller (w/ bypass)
IntelliCenter Load Center 522041 w/ i5P Personality Kit 521909 & Wi-Fi Bridge 522475Z
IC60 SWG 521105
5 x MicroBrite Color LED Lights (all facing away from the house)
Plumbing:
2 Skimmers w/ 2.5" Pipe (each separately plumbed to the pad)
8 Returns w/ 2.5" Pipe for the long segment back to the pool
Unions for all equipment at the pad
Minimum 18" straight pipe before the SWG
Center water feature 3 x sheers & 2 x flanking Venetian bronze spouts embedded in wall
No Main Drain
No Suction Port
1/2" Injection Port for Stenner Pump (after SWG)
Jandy Neverlube Valves
Fill line controlled by sprinkler controller (as a zone)
Overflow line
Electrical:
Pentair Load Center (w/ HEPD 80 surge protection)
GFCI at pad and pavilion
Extra 2" empty conduit to pavilion
Light at equipment pad
Volt Lighting 300W landscape lighting transformer
7 x Volt Lighting hardscape lights embedded in wall
Deck:
1,100 square feet white travertine Versailles pattern
Deck and area drains w/ 4" drain pipes to street
Contrasting travertine coping
Removable hand rail
Miscellaneous:
Pentair Warrior SE Robot Cleaner
12' x 12' Pavilion w/ 2 x sconces, 2 x ceiling flood lights, 4 x can lights, ceiling fan, GFCI outlets
5 x Umbrella sleeves
Backyard faces east (pool will be mostly in the shade during the hot Texas afternoon)
Overview:
12" Shelf
2 x Benches
~21k Gallons
Pentair Equipment:
IC60 SWG 521105
Plumbing:
No Main Drain
No Suction Port
Overflow line
Electrical:
Deck:
Removable hand rail
Miscellaneous:
