Hire him to punch another hole & bulkhead into & run a return pipe to it. 2 equalizers & a throttled return will out you in easy street.
What confuses me is that I pic u posted port on left is low and port on right is high. Judging by water level in pool I think maybe lower drain may be equal to top of water but not right drain. Either way the waterfall running will constantly raise ur PH I would do irrigation box w a T in there and add a regular return
The longest it should have sat was 3 days.........any longer and the risk for an algae outbreak goes up every day Time do do some pushing to get things going.
Is the equipment set up and ready to power up?
Kim
IF he does not show up today we can talk you through turning things on..........we have to get some chlorine in that pool!
Do you have a test kit yet? If so please run out and and pull some water and test it. (don't bother with the CYA test).
