Thanks to everyone on this forum, I've been lurking for a few months and gleaning some ideas. I signed the PB contract in early October and they broke ground today. Some specs:
16x32' gunnite, 3.5 ft shallow, 7 ft deep end
2x4' water feature/jump platform, natural stone
8x10' tanning ledge (umbrella sheath, 2 bubblers)
Wet edge signature matrix pebble finish
Stamped coping
Spray deck, not really sure what that is, just recommended over Kool deck
2 skimmers, 4 returns
Swimout, no handrail or ladder
This PB uses Jandy and Hayward, and from my bids seems to be an even split between Pentair and Jandy. I hate that Jandy still doesn't support Amazon Echo or Google Home, but I may try figuring something out with a raspberry pi to USB/RS-485 and some existing libraries on github for the Jandy controller. I just emailed Zodiac a couple days ago and got a simple response- they don't currently support any home automation. Regardless, I'm getting the iAqualink and will probably regret spending the money on it later.
Jandy SWG, 40k gal
Jandy CL series cartidge filter (340 sqft)
Jandy VS pump - ??? model
Jandy controller - ??? model
Raypak heat pump with cooling option, originally Hayward but it's discontinued
Dolphin 400
3x Jandy color LEDs
This PB doesn't like SWG, as I've read many are prone to do and do ozone standard instead. They're worried the salt will corrode the heat pump. Raypak manual seems cool with salt, and seems highly recommended by this forum so no doubts there. I've read the zinc sacrificial anodes are a just in case thing but jury is still out on their effectiveness. If stray currents are a concern, just make sure equipment and water is properly bonded. Well here's the rub, interesting story:
Hard time convincing PB that my water needs to be bonded by 9 sq inches of metal, as per NEC 680.26, and I have no metal rail/ladder in my build, and heat pump will usually be bypassed. I copy/paste the code and try an appeal to common sense: if a live wire touches pool water, where's the current going to go? Can't trip a breaker with no path to ground, you've just got an electrified pool. I emailed the head county inspector, no response for weeks. Called again today, find out from a different inspector that they just learned that provision and will start enforcing it. They learned it from my email weeks ago that I got no response on. Anyway, PB already agreed to install the Perma-Cast PB2008 I bought on amazon for $22. I'll tell him soon enough that the inspectors are caught up now.
Here are some pics. Design should shift the pool right so the deck lines up with the edge of the porch.
Stamped coping
Jandy SWG, 40k gal
Dolphin 400
3x Jandy color LEDs
