- Jan 24, 2020
- 219
- Plaster
- Pentair Intellichlor IC-60
Design: 18x35 w/ 7x13 Baja + 7x9 raised spa
Pool: ~25K gallons
Spa: ~1178 gallons (8-10 person)
EQUIPMENT
Pool: ~25K gallons
Baja shelf: 7x13 ~10-12” water line deep
Shallow end: 3 1/2 ft
Deep end: 8-9 ft
Pump: IntelliFlo VSF 011056 (pool pump)
Plumbing: 3-4 returns, 2" double main suction at the deep end,1 skimmer, Auto-fill, Vacuum inlet, (robot may use in the future)
Lighting: 4 Microbrites (4 lights in pool facing away from house, 1-2 on Baja & 2-3 spread across length of pool)
Tile & Coping: 14" cast in place concrete coping around pool and spa, tile TBD
Plaster: TBD, Stonescapes – Aqua Blue minipebble, WetEdge - Primera stone, Hydrazzo | Mediterranean Blue, Hydrazzo Classico | Oceana Blu
Size: 7x9, 12-18" raised spa
Seating: Split level depth all the way around (20-~24")
Jets: Single per 8 seats (hydro therapy parajets), 2 seats with multi parajets?
Pump: IntelliFloXF VSF 022056 (spa pump), TBD if we need to utilize both pumps for number of jets
Plumbing: ~2"? intake and return to jets (confirming idea for pump and 60-70ft from equipment)
Blower: TBD; may just go with venturi stqand pipe at the pad
Lighting: 1 microbrite
EQUIPMENT
Pool/Spa Pump -- Pentair Intelliflo VSF Variable Speed and Variable Flow Pump (Model: 011056)
Spa Pump -- Pentair IntellifloXF VSF 3HP 230V Variable Speed and Variable Flow Pump (Model: 022056)
Filter -- Pentair Quad 100 D.E./Cartridge Filter sqft with NO backwash installed (Model: 188594)
Heater -- Pentair MasterTemp 400K BTU Natural Gas Heater (Model: 460736)
Controller -- Pentair IntelliCenter i10PS (Model: 521908-IC60)
Pentair IntelliCenter i10PSIC60 Kit - Pool and Spa with Load Center and IC60
Installing the IntelliCenter saves the electrician from installing a subpanel, timers, and switches.
The IC-60 power/control cable plugs into the IpH control panel and the IpH control panel plugs into the IntelliCenter
Chlorination / Salt System -- Pentair IntelliChlor (IC-60) (Model: 521105)
Breakers for Controller panel - PA220GF GFCI BREAKER 2-POLE 20A (For Intelliflo Pumps) – (Model: PA220GF)
pH Dosing System -- Pentair IntelliPH pH Controller (Model: 521377)
Lighting – Pentair MicroBrite Color LED Light - 12V - 100’ Cord fit a 1 1/2” standard pipe. (Model: 620425)
Skimmer - Pentair Skimmer Bermuda ABS for Concrete 2" Slip (Model: 506361)
Pour in place type lid
Valve Actuators - Pentair IntelliValve Actuators (Model: 521485)
Valves -- Jandy "no lube" Valves (Models: 4715, 4716,..)
Check Valves -- Jandy check valves (Model: 7305)
Water leveler (autofill) – Pentair T40BG or Paramount ParaLevel?
Junction box – Intermatic Junction box for lights (nothing to do with IntelliCenter)
Robot - Active 20/ Dolphin S200
Suction Cleaner - Rebel
