Do you have pool lights? You need a 120V GFCI CB for lights?
The pool light is out of commission as it had a leak and needs replaced. It was an older(?) style 12 V that had a transformer that is also shot. It was one of those old ones that had a color wheel in the light and water got into the housing and does not work anymore. I am not sure if I will replace with a new 120 V light or a 12 V light as I will have to wait until I can get into the pool and see what kind of light would fit into the existing housing in the pool. There are still some open spots in the control panel that I can wire a new light or a transformer to once I get to the light.
Will you install a convenience GFCI outlet on the lower right of the panel?
I am not sure; there are other outlets outside in the area and was not sure if I needed to add another one to the panel.
The control panel did not need to be 240V. I would have used a 120V CB for the control panel power. That gives you another slot for a 120V pool light CB.
I had this breaker already and just used it but agree can replace and just use 120 if I get tight on slots in the future.
Heater should be connected to the LOAD side of the filter/pump relay so it does not run if the pump is not running.
Ok; so wire it to the load side same as the SWG so it can only run when the pump is running.
Noted - I will read and get this added to the panel. Did you use a panel mounted one or something like the FirstSurge? I have used a FirstSurge before on our main panel and it seems this is the best and more safe option for this panel associated with the pool and since it is located outside.You should install a Surge Protection Device connected to a 20A 240V CB in the loweest slot of the panel - Electrical Surge Protection - Further Reading
Did you also use any of the RS-485 isolators on those control cables or just the power supply? I did not see any options for the communications cables and only the RS-485 style communications.
Thanks for the suggestions!! If I have any other power questions I will post and I will get another picture posted on the control wires when I get to that point.
See photo for revised on the heater power location and addition of the SPD.
