- Sep 10, 2020
- 33
- Plaster
- Pentair Intellichlor IC-40
Hey y’all, we finally got our heat pump installed after waiting 6 months after the rest of the pool was finished. The PB installed the AquaCal Superquiet Heatwave Heat and Cool on Friday morning. I came home around lunch to check it out. They had left the pool on spa mode, presumable to heat up the hot tub for when we got home. Only problem is, it wasn’t working. I did see some water puddled around what appears to be the condensate drain, so that tells me it was working at some point, probably was working when they left. The fan wasn’t on, it wasn’t producing heat, and The screen said heater was off. Pool water was 72°, temp was set to 100°. I couldn’t stay home long so I left for a few hours and when I came back, still no life to the heater. No more water around the condensate hole. I looked on the app and it has an alert, “Pool Solar Temp Sensor”. Could this be why it’s not working? The PB said they will come back Monday and look at it, but I didn’t know if it was an east fix, or a setting that needs to be clicked on or off. We do not have solar heat. Any help would be greatly appreciated.
