- Jun 8, 2019
- 4,581
- Vinyl
- Pentair Intellichlor IC-60
How many gallons are in your pool?
What are you trying to accomplish? Did you read the directions for the SLAM Process to get rid of your algae?
Hi Kim,SLAM=keeping the FC as close to your SLAM level as much as possible. Every time the FC dips below SLAM level the algae can regroup.
Try for at least 4 FC tests and doses.
1.first thing in the morning
2. Right when get home (take off good clothes)
3. After dinner
4. Right before bed.
If you can sneak home at lunch then the SLAM will go even faster.
Leave the pump running 24/7 and brush at least once a day.
Kim![]()
Check and adjust the PH to between 7.2 and 7.5. The PH test isn’t reliable during SLAMing so make sure to take care of this before you start.
Oh I see. The pH got raised when I was adjusting for the TA level with baking soda. So should I bring pH down by adding muriatic acid for the SLAM process to work better? Thanks!
So should I expect the FC level to continuously go down each time I test and replenish with liquid chlorine? The pool math app suggested to SLAM and target for FC =10ppm. Is that what I should be doing?
I don’t even know how to perform backwashing.
