My Superflo VST is a mess inside
Did you fill the volute with water?
Yep, I can see that getting pulled up by the pump. Double checked the lid was tight, and the union before the pump has an o-ring. Gonna try again and then check the union from the pipe direct to the pump, though it wasn’t taken apart.
Not putting it under pressure. Just filling with water first. Upon reflection that won’t matter because excess water not needed to prime would just fill the air spaces elsewhere in the system.
Still don’t know why it wouldn’t prime, even if the shaft seal wasn’t tight against the seal plate. Wouldn’t it push out water instead of taking in air?
There is a suction side leak. Go through it again. Clean the orings for any dirt, clean the mating surfaces, relive again. This happened to me too.
There’s only two unions before the pump, and both were checked at least three times. Pump lid checked and lubed again. Unless my jandy valve started leaking, not much else to check. :/
