- Apr 19, 2021
- 4
- Plaster
- Pentair Intellichlor IC-40
two questions!
I've scoured previous threads, but haven't seen this specific question.
My heater will fire and run for 20-30 seconds SOMETIMES, and sometimes will run for several minutes at a time before failing with error E05
Through the many helpful posts in this forum, I learned to hold the "on" button for 10 seconds to get the system's take on the stack flue sensor temperature, but I also had a hand-held laser temperature sensor
While the heater was running for about 2-3 minutes, The flue sensor temp read 210 but my hand-held laser thermometer read 326
1) Can I assume that the issue is the stack flue sensor? The forums show SO many potential causes of this error!
2) I see tons of compatible SFS replacements for $20-30 on Amazon. I looked up a replacement sensor at my local Leslie's Pool place, and dang... $150! Is it worth spending that much money on the SFS?
