I need help. I do pool inspections as a side job. I was recently at an inspection, and performed a function check, turned all of the pool pumps on and off: pool, spa, water wall, and water slide pumps. The next day I got a call from the homeowner saying his pool pump wouldn't turn on. His pool guy said I damaged the impeller (which he "had" to replace $300) and said I damaged the impeller by turning the pumps on and off too quickly. He wasn't there and that's not what i did. It's worth noting that the pumps/pool equipment are controlled via a remote panel located inside the home. While all the pumps were on, At the pool equipment I put the pool panel in service mode and once I did that, the pumps shut down. Then I proceeded to turn each pump on one by one and they all came on. Once I observed everything was functional, I switched the panel back into auto mode and all the pumps turned back on normally with no issues at the pumps.
Now during the inspection, two pumps were leaking water from the bottom, the filter bowl pressure was excessive at 30 psi, and there were multiple plumbing leaks at Valves. All of which indicate a problem right? So I'm having trouble understanding how I damaged the impeller by doing a normal function check. Based on the conditions observed, It seemed as though there was an impending failure waiting to happen at the pool equipment. Your thoughts?
Thanks for the input and advice in advance.
