Hello everyone. There have been some good conversations here about similar problems, but none have fixed my issue. The pump has been working normally on schedule until today. The pump seems to be talking to the easy touch control box as when I open the panel on the pump it says "display not in use". However there are times when it seems it's not talking to the pump and the display is active even though I'm in normal "schedule" mode. The pump is about 10 years old, but I can get it to run manually in service mode so the pump itself is good. I ran a self test diagnostics on the easy touch and it came up with an error code 4. When I looked that up it says a button is stuck, but I can't find any buttons not working properly. The other pumps ran as designed during the self test, but not the main pump. My guess is a bad control board.
Any ideas? Below is what I have. Thanks for any help.
