Hello,
We went to open our pool in early June, pool had about 2 feet of water on the bottom. Called a company that plugged the main drain for about $200. They say they can fix the leak to allow us to use the main drain again, however, it will require some jack hammering around the drain. They said the issue is likely the nylon fitting, which deteriorates over time (this is a pool from the 1960's/70's). They said they may have to drill through the shell of the pool, if the main drain pipe is leaking. They estimate the repair will cost around $900 either way. They said they can come in a week or two to fix it. The pool is about empty now.
Given my current situation. Is it worth fixing the main drain? If I fix this drain, will this issue just come back to drain all of my water in a year or two? Will the jack hammering around the drain, damage the gunite elsewhere due to vibrations? Should I abandon the main drain and just rely on the plug for now? Will the plug be enough to prevent this pool from leaking long-term? I want to do the best long term solution, now is the time. With that said, I probably won't be able to replaster the pool for at least a few years, maybe longer.
-Xavier
-Xavier
