- Includes self-test as required by UL 943 as an added safety feature.
Prevent a ground fault in construction applications like spas, hot tubs, kitchens or bathrooms with this Siemens Double Pole Type QPF GFCI Circuit Breaker.
www.homedepot.com
Underwriters Lab (UL) 943 requires that a Self Test and Lockout feature be included in all GFCI circuit breaker devices manufactured after June 29th, 2015.
Testing GFCIs on a monthly basis is a good idea that is sometimes forgotten.
UL suggests GFCI devices be tested every 30 days after installation to ensure they are properly working.
Now the new Self Test and Lockout feature enables the GFCI circuit breaker to automatically and continuously test itself to ensure that it is working properly.
If it is detected that the device has been compromised, the device trips itself and locks out the homeowner from resetting the device, reducing the possibility of the homeowner incorrectly assuming that the device was tripped to prevent a ground fault.
This will help guarantee the best protection is given to your home at all times.
A Self-Test GFCI receptacle has all the features of a conventional GFCI receptacle.
In addition, this receptacle performs a self-test every 15 minutes to confirm the GFCI electronics are functional.
There are 2 indicator lights on the face of the GFCI device.
The first light will flash green or red to indicate status. The second light will flash amber to indicate a trip or fault.
Welcome to the Leviton Blog > How to > Self-Test GFCI Indicators section of the Leviton Blogsite. This section has the following description: A Self-Test GFCI receptacle has all the features of a conventional GFCI receptacle. In addition, this receptacle performs a self-test every 15 minutes to...
blog.leviton.com
