Has anyone tried throwing a magic eraser in the skimmer to speed up algae removal? Any possible downsides?
Just in the interest of completeness and accuracy regarding "containing formaldehyde" . SnopesOk, although I'm pretty sure OP is just having a laugh, I guess for someone coming across this I better put the answer in.
Those things are made of melamine (CYA testing reagent), sodium bisulfate (pH reducer), and formaldehyde. None of these do anything to hurt algae. There is no science here, just gullible people who fall for and forward things that should really make them go "that doesn't seem likely". Most of them are probably scared of chlorine but then suggest putting formaldehyde in their water ?
So anybody arriving here in search of this question: welcome to TFP! Your skepticism has served you well and brought you to the best place on the internet for pool care. Stick around for actual ways to clear a green pool and keep it clear. Please make an account, check out the ABCs of Pool Water Chemistry, and don't be afraid to ask questions. Just please, use the eraser for its intended purposes and don't just throw them in the skimmer hoping for a miracle
The way it hurts is that it wastes everyone's time.If you haven’t then no need to comment unless you have a valid reason why it could hurt.
Try it and see, I don't see the harm.I’m fully aware of how to get my pool clean but I need it clean overnight and have seen this and wondered if anyone has ACTUALLY TRIED IT. If you haven’t then no need to comment unless you have a valid reason why it could hurt. Thanks.
Ok, out of curiosity I tried it. Turned my pool in to a vat of bubbling green acid, which some crazy haired scientist and his grandson then jumped in to. I tried to put a ladle in it and it melted, so that was definitely real acid.
