- May 3, 2007
- 18,094
- Plaster
- Hayward Aqua Rite (T-15)
Re: Low flow pumps - Is Air in Solar system ok?
I have a controller which ramps up the speed to prime the panels, then sets the speed to a lower RPM after priming. But my panels are about 2M off the ground so I can run them on the same low speed with or without solar anyway.
But how long does solar usually run anyway? Maybe that is all you need in terms of run time? Most pools can get away with less than 2 hrs of run time.
Might be cheaper to find a VS that has relay control inputs (e.g. Pentair SuperFlo VS, Hayward MaxFlo VS) and sell the Davey.what I could do is swap the solar pump for another eco pump, and adjust it. That might save some wattage vs the basic solar pump.
