- May 3, 2007
- 18,089
- Plaster
- Hayward Aqua Rite (T-15)
Re: Low flow pumps - Is Air in Solar system ok?
I still think your best option is really to remove the solar pump and run the main pump at a higher RPM. I know you don't want to do this but you are fighting physics here. There is a critical flow rate required to purge water out of a vertical pipe (check valve or no check valve). This flow rate is approximately 40 GPM for a two story install. So if the solar pump does not have enough head to raise the water to the panels at 40 GPM, then it is unlikely this setup will ever work properly.
What is the make/model of your solar pump?
What is the height of the panels over the pump?
Plus the slower you run water through panels, the less efficient they are. If you are interested in getting the maximum heat out of the panels, you need to run at higher flow rates. Generally 0.1 GPM/sq-ft is optimal. The efficiency drops off pretty quickly when operating at lower flow rates so you will be forced to run the pump longer for the same heat gain. If you are truly interested in efficiency, it may be better to run the pump at higher RPM for a shorter period of time to get the same heat gain than try to get the system to work they way it is now.
