- May 3, 2007
- 18,089
- Plaster
- Hayward Aqua Rite (T-15)
Re: Low flow pumps - Is Air in Solar system ok?
Possibly. The panels drain away from the VRV in both directions so the noise is probably the water falling back down to the VRV from the panels higher up.Had I put it at the very highest point in my system, would it have been quieter? I couldn't find a consensus about the optimum placement for a VRV when I was designing my system. Highest point of panels? Lowest point of panels? Just below the roof? A few feet above the equipment pad? Etc.
Yes. The heat transfer from the panels decreases with flow rate so to get to the same temperature, run time will need to be longer.And if that's the case, isn't that making his system even less efficient, by compromising the flow even more?
