I've been a pool owner for 3 years. Year one was easy, but the last two years have been a never ending battle with algae. I don't feel like it should be this hard, but I must be missing something.
Here's what I've done:
The best luck I have is with the phosphate killer. This gives me a pile of dead algae on the bottom (which I vacuum to waste) and the water clears up. Then it's cloudy and green again in a day or two. I feel like I have to use phosphate killer every 1-2 weeks though, which is not ideal.
Can anyone think of anything else I might be doing wrong? Are there issues with my filter (it generally seems to be working, based on the color of the backwash water)?
FWIW, in year 1 (when I was a new pool owner and everything went great), I never had to use phosphate killer, never had any sign of algae (other than when the pool was opened), and rarely brushed the walls.
- Make sure pH and alkalinity is balanced
- CYA was high at one point, so drained some water and added new water until it was in the ideal 30-50 range
- Checking phosphates multiple times a week, using phosphate killer if it gets over 300. I use a preventative phosphate treatment weekly, but that doesn't seem to keep up, so I have to use the killer.
- Brushing the pool walls daily
- Running my robo-vacuum at least once a day
- Backwashing the sand filter daily (lots of really green water gets expelled)
- Double-shocking the pool. Kept free chlorine > 4 for quite awhile.
- Running the filter 24/7
- I try to skim the pool if it gets a lot of leaves in it, but I live out in the country and there are a lot of trees around, so I'm sure there are a lot of smaller particles that get in there.
- I haven't used algaecide since many people recommend not doing that
