Here’s a picture of my multimeter - I don’t believe it can test for capacitance since there’s no symbol on the rotary dial (but it does have the capability in the instruction manual for some reason). It says to turn the dial to a symbol that doesn’t exist on my model.
That motor is beyond end of life. A long-time seal leak has destroyed it. The noise you hear is, most likely, the rotor being pulled into the stator because the bearings are so bad. This motor can replace it:I believe the pool panel is receiving 240V, each of the red and black line feeds read 120V with a multimeter.
The circulating pump is on a double pole 15A breaker on the bottom of the picture.
Brand | Pentair |
EnclosureDesign | TEFC |
FinishColor | Almond |
FlangeType | Square |
ForUseWith | WhisperFlo® High Performance Pumps |
FrequencyRating | 60 Hz |
HP | 1 |
Item | Motor |
NumberOfSpeed | 1-Speed |
Phase | 3-Phase |
VoltageRating | 208/230/460 V |
It is, same as a VSP without the VFD. Used many of them, especially in some areas of my town that have voltage of about 208V (downtown). They work well.This looks like a single speed 3 phase pump motor. 354805S.
It won't work for this pump.
Brand Pentair EnclosureDesign TEFC FinishColor Almond FlangeType Square ForUseWith WhisperFlo® High Performance Pumps FrequencyRating 60 Hz HP 1 Item Motor NumberOfSpeed 1-Speed Phase 3-Phase VoltageRating 208/230/460 V
POOL360 - 1HP 3PH 230/460V ALMOND SQFL ODP MOTOR
1HP 3PH 230/460V ALMOND SQFL ODP MOTORpool360.poolcorp.com
Well, ya got me. Paid more attention to the picture than the specs. Looks the same. I meant this motor:208 is a three-phase voltage.
Unless you have 3 phase power or a drive, it won't work.
Three phase has three power wires.
Unfortunately, you likely will experience nuisance tripping with a SquareD GFCB. That's why Pentair has their own, a Seimans QPF2 with a Pentair label. Check Home Depot for the Siemans one.thank you everyone for the suggestions - just ordered a new IntelliFlo i2 and a new 20A 2 pole GFI square d breaker.
Ok I’ll switch it for that one instead.Unfortunately, you likely will experience nuisance tripping with a SquareD GFCB. That's why Pentair has their own, a Seimans QPF2 with a Pentair label. Check Home Depot for the Siemans one.
