Looking for input on new pool build in Spring, TX
Wildkarrde21
8
Houston, TX
Hi TFP!
Been lurking for a bit and just signed a contract on a new pool build in Spring, TX (suburb north of Houston) though I have until next Wed 9/15/21 to back out without any penalties. Was recommended this forum and thought I’d have you experts look it over before it’s too late! Let me know if any additional info needs to be added:
Pool/Spa Specifications
Shape: Geometric (Rectangle)
Pool Dimensions: 38’ x 15’
Depth: 3’6” to 5’6”
Volume: 17400 gallons
Spa dimensions: 6’ x 8’, 12” above decking
Equipment
Filter: Pentair Clean & Clear Plus 520
Pump: Pentair Intelliflo VSF
Cleaner: Choice of either Polaris 280 (w/booster pump) or Polaris 9450 Robotic - leaning towards robotic as we don't have many trees
Pool Skimmers: 2 Swimquip 2” tan
Pool Lights: 2 Pentair Intellibrite 5G
Spa Light: 1 Pentair Intellibrite 5G
Main Drain: Dual Channel Drain (Aqua Star Drain covers to be flush with floor)
Inlets: 2”
Remote System: Pentair EasyTouch 8 (phone app) - asked about Intellicenter but they don't support it. If it's really a big deal I can try and push on it.
Air Blower: 1.5HP QT
Spa Jets: 8 therapy jets
Heater: Pentair MasterTemp 400k BTU Natural Gas
Sanitation System: IC40 salt cell
Structural Specifications
ExcavationWood Guidelines as Required With Vertical Stakes
Steel (Beam)12” Box Beam #4 – All Intersections Tied
Steel (Wall/Floor)8” Grid W#3 – All Intersections Tied
Gunite (Beam)12” X 12”
Gunite (Wall/Floor)6” Minimum
Gunite (Coves)8”
Steps & BenchesPer Plan – tanning ledge with 2 bubblers and 6 umbrella sleeves
Electrical Specifications
Ground DesignPer Established Code
Sub PanelSub Panel With Electrical Breakers
CodeLicensed Electrician
Plumbing Specifications
Hydraulic Design8 Pool Returns
Pipe2”
Valves2” Jandy
Fill LineAuto Fill
Overflow Line2” Run with Pop-up to street
Pool Plumbing2”
Pump Connections2”
Finish Specifications
Tile6” x 6” tumbled travertine or standard mosaic tile
CopingTravertine
Interior FinishPebble Sheen - Blue Surf
Deck Specifications
Deck Type864 sq ft stamped concrete (cap existing), brushed step pads
Sub BaseSelect Fill
Steel ReinforcementRebar tied on 12” center
Deck DowelsYes, deck dowels / stirrups from pool beam tied to deck rebar
Drainage System4” Rigid PVC with pop-up to street
Contract terms:
60% at gunite
20% at tile & coping
20% at plaster
Thank you in advance for any insight you're able to provide!
Renderings:
The contract: https://drive.google.com/file/d/1zA7K8OUgPKL_7k5O6tF6rEifZ--AvSQu/view?usp=sharing
HermanTX
2,549
Katy TX
Overall looks great. I like the pump, heater, filter and SWCG. My suggestions are:
Ask that the 2 skimmers be independently plumbed back to the equipment pad and have valve on each for control
I would avoid the Polaris 280 (although that is what I have) but going robotic without a booster pump is a better setup
Can you hold 5% of payment back till finish of pool? They have 100% of payment before plaster and you have no leverage if anything on punch list needs to be done
The ET automation will be fine. But you do not mention screenlogic which is the software to run on your PC. It is easier to program using your PC (from what I have read on the forum).
You do not mention any water features - do you have any other than spillover from spa to pool?
Post a picture when you can.
Reactions: Wildkarrde21
kimkats
49,055
Tallahassee, FL
Sure can tell you have been doing some reading! Well done!
Make sure the depth is WATER depth (from floor of pool to the middle of the skimmer opening) instead of from floor to bottom of coping.
Shelf-how deep (WATER depth)? Use a ruler to see how deep 6", 8", 10", and 12" of water is. Think about sitting on the shelf-where do you want the water to hit you if sitting on the shelf? Chairs-do you want your bum in or above the water?
-Valves-make sure they are all "good" ones aka can be rebuilt if/when needed.
-Unions-make sure there are unions on everything. Make life much easier down the road
-equipment pad light-you will thank you the first time youhave to go out there at night.
-oversized pad-you do not want to have to play twister to work on the equipment
I am sure I will think of more once I see your plans.
Kim:kim:
ajw22
28,522
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
As Kim said specify that depth is final water depth, not depth to bond beam.
I prefer a separate pump for the spa jets. Especially if you expect a strong flow of water from the jets. A strong flow needs 10-15 GPM per jest. With 8 jets you need 80-120 gpm of water flow. You will not get 80 gpm of water flow through the filter and heater.
Spa pipes for the jets should be 3" suction and at least 2 1/2" to jets.
2 skimmers is ok, how many returns?
Push for IntelliCenter.
I would not accept the payment schedule. I want at least a 10% holdback due 2 weeks after entire pool and all equipment is satisfactorily operational.
Some people are having problems with the way their spas are constructed with low water flow out of the jets or air blowers that overheat and stop. You don't find out those problems until the entire pool is running and you can test everything. You may have one of the good builders or you may not. But any builder who wants 100% payment at plaster leaves the customer with no recourse for problems.
IntelliBrite lights are expensive and don't last long. Read Pentair LED Pool Lights - Further Reading Consider Microbrite lights so you have options to replace them with other nicheless lights in the future.
Wildkarrde21
8
Houston, TX
No water features other than the spillover from the spa.
Welcome to TFP.
In the document they sent me it says 8 returns under Hydraulic Design. Is that what you meant?
I’ll put together a bunch of the suggestions together to send to the builder on Monday. Thanks!
ajw22
28,522
Northern NJ
Could be although 8 sounds like overkill. 3 to 5 is more then adequate.
Do the pool plans show where the skimmers and returns will be placed?
Wildkarrde21
8
Houston, TX
Heard back from the pool builder regarding a few things:
  • Water depth is confirmed to be to skimmer line.
  • Equipment pad is 3' x 9', is that oversized enough for the equipment I listed?
  • Regarding the contract payment terms, I had suggested that I was uncomfortable with handing over all my money before the pool was even running and proposed a 10% holdback until the pool was started up. This is the response I got:
We kick the equipment on very soon after the pool is full of water. The start up service is a 3 week service, so we can't be very flexible with the payment because at that point, we have paid every subcontractor in full for your pool build and we then have our pool maintenance guys working on your start up. If you just want to hold the PebbleSheen draw till the equipment comes on, I'm sure [Owner names] will be flexible with that, but waiting the full 3 weeks doesn't work well for us.
Is that an acceptable compromise? FYI, the other bids we've received all had similar terms.
Reactions: kimkats
HermanTX
2,549
Katy TX
I think you are close, in fact, just asking them that point provided you a dialog that you can work with. Obviously holding 3 weeks is maybe not reasonable but a couple days after pool is running is good. Just have your punch list ready before the pool is filled and provide the PB with the list. You can then wait a day or so when pool is filled to ensure equipment works and no leaks. You can always renegotiate if there are any major issues found upon equipment start up.
ajw22
28,522
Northern NJ
That is a BS answer since you are basically withholding the PB's profit. You think he is making less then 10% on the contract? With 90% paid he has the money to pay all subcontractors and for the wholesale price of equipment.
What % would the Pebblesheen draw be?
Wildkarrde21
8
Houston, TX
I believe the % for the PebbleSheen would be the Plaster stage(?) they have in their payment schedule, so it would be 20%. The way I read her response is that it seems like they'll allow me to hold that percentage until after the pool is filled and equipment is turned on. I can try and get it pushed to a few days afterwards to ensure equipment works and no leaks, plus punch list completion.
Reactions: HermanTX
ajw22
28,522
Northern NJ
You have the parameters to negotiate from.
Until all the supply chain issues are resolved people are being left with various IOUs by the Pool Builders in a lot of builds.
Once the pool is completed and started up you will pay them the final payment when it meets your acceptance criteria regardless of the date in the contract.
HermanTX
2,549
Katy TX
See this post where holding back till equipment installed should hopefully help resolve their issue. This illustrates the importance of having some leverage as mistakes and errors do occur.
