Hey all!
I've got a pool at the house I have owned for about 3 years now. The best I can tell is the pool was built in 2006 and overhauled once with pebble tec but most if not all of the equipment is original. The filter is a Hayward C5520BHMB, pump is a Pentair SuperFlo 340040. Pool is about 25,000 gallons with an offset spa with constant spillover into the pool, heater and a rock waterfall on a separate pump. Automation is Aqualogic which also appears original to the pool with salt water generator.
The filter housing is really showing its age but still functions properly as far as I can tell, same with the pump although I believe it adds quite a bit to my electric bill. I am looking to for sure replace the pump but possibly also the filter. The filter seems the easy part though as I can find a similar Hayward 525 sq ft filter easily. The pump is the tricky part with the new energy efficient regulations. I don't know how the variable speed can interact with the current automation. I don't really want to change the automation as it works perfectly.
Can you help guide me in the correct direction of a pump that would be a drop in replacement and work with my current automation?
Thank you in advance!
