Because I left a good job down in da city, and never do anything nice... and easy...
I encased the light strings in black split cable tubing and then attached that to my fence with stainless steel wire. The fence is black, so from a ways away the tubing is near invisible. I used the split tubing for two reasons:
- Since the lights are exposed to the sun year round, the tubing will help protect the wiring from UV. The tubing has some UV protection, but I expect that will fail eventually, but then I'll just get more tubing. The tubing is considerably cheaper than the lights.
- I carefully aligned the tubing with the split facing down. This forces all the lights downward, and positions them nice and neat and in a straight-ish line. Without the tubing, the lights would point every which way. I felt this was important, and worth the considerable extra effort, because no one in their right mind will ever notice.
I used stainless steel wire because that is impervious to the sun. Plastic cable ties fail very fast where I live. I strung 200' of this stuff! All along the back of my yard!!
And if that's not nutty enough for ya: the lights are not replaceable, they're molded into the string. Which is good because that makes them waterproof, but bad because, well, they can't be replaced. So every eight feet I created a loop that included one light, and stuffed that into the cable tube. If any light burns out or otherwise fails, I'll "un-loop" the spare and re-adjust that 8'-section. I'll loop up the burned out one and hide it. If two burn out in the same 8', I'll use the next section's spare. If three burn out I'll be inconsolable.
All 200' (400 lights!) are less than 50 watts total. Same as my Volt garden lights. So when both are on it lights up my whole yard for 100 watts!
