If opening and closing the valve doesn’t stop the leak then it may have been damaged over winter. It probably needs to be replaced. See INYO Pools for parts -
Also, you may be able to completely unscrewed the Open/Close knob and remove it from the valve body. Check to see if the rubber o-ring at the end is chewed up or damaged. You may be able to replace the o-ring.
Nope opening and closing didn't stop it. Will check the o-ring but that gauge is brand new. I installed the whole thing less than a month ago. We did have a pretty cold spell for a few days so hoping that didn't damage it.
