Another "fun" discovery while doing some renovations and having a hard time getting someone out to actually look at it/fix it so thought I'd ask in case there is a way to fix this that isn't terribly difficult.
I've done some digging and I was surprised to find this copper pipe as the apparent source...it's associated with one of the jets in the spa and only leaks when the pump is off. If the pump is turned off, water flows out, but when turned on, water gets sucked back in. I'm thinking this is possibly an old line from heater, so venturi effect keeps suction so it doesn't leak when pump is running but as soon as pump is off, pressure is greater in pool/spa, so water flows out. The same happens if I cover up the jet while the pump is running (see pics/video). There were several roots around it, a huge one underneath and then several smaller roots that were all wrapped around the area where it enters the concrete so I suspect that is the "root" cause for compromise of the pipe (or corrosion or something that was knocked loose when the pool was replastered).
The old gas heater has long since been disconnected from the pool system (and no plans to reinstall one) so I think all I need to do is find a good way to seal this off, but not sure how feasible that is with it sealed in the concrete outside of pool.
Any ideas? Or is this definitely a job for professionals? Thanks in advance for any advice!
Video of water flow with pump on and off: Before digging pump on and off.MOV
Video of exposed pipe with pump on: Copper pipe pump on.MOV
