Hi,
A little history on my pool...Please stay with me
I live in North West NJ. Our new IG pool build started last September (dug, built, filled, covered in December. By February I noticed 20-30 inches of water loss. I struggled to keep the 5 dollar wal mart crummy tarp that the cheap pool builder provided in place and intact but it was torn up within a week. TLDR; After battling with the electrician and the pool builder for weeks, it was discovered we had a leak in our wet niche (light housing). We dug it up and saw it spraying water out of the top. Pool builder replaced it. While filling it back up, I observed for a day or so whether it sprung any more leaks in that area. The conduit line was also partially dug up and exposed. No leaks. No ground saturation.
We filled that hole with sand, then dirt. Built the patio. All good.
A near drought of a summer in NJ with 90-95+ degree temps all summer. I was losing 1/4 - 1/5 inch per day so I was filling up 3-4 inches once or twice per week between early July and late august. Out of caution I did multiple bucket tests and observed the water level dropping in the bucket along side the water in the pool. It was just evap. Other neighbors reported similar situations with water loss. I also purchased a dye injector to detect leaks. Tested around the pool light housing, as many corners as I could, 99% sure I tested the main drain, all fixtures (returns, skimmers etc), steps... nada. All good.
End of August rolls around... water loss slows down significantly. We get some rain into september. I don't think I added water to my pool once in September...water loss simply stopped it would appear. We had a little rain here and there, but it was well below average still. We close the pool up September 30. Hired someone to do it this first time because he was also installing the pool cover.
Pool cover is solid with a mesh square in the center. According to the guy who installed it, it is supposed to have some sag and is designed that way so water can drain toward the center and into the pool. So it isn't as tight as a solid cover (like my last IG pool).
Yesterday, something told me to look under the cover. Bam...20+ inches of water gone again. Now, the water is absolutely frigid!!! If I had to guess, 40-50 degree range. However, the ambient air under the cover was really really hot, you saw droplets of water on the underside of the cover. I took the cover partially off and performed more leak detection in areas that I could (stairs, corners, reached down to the light...all good. I tried to get into the deep end to do the main drain, but it was too cold. Im currently doing another bucket test with the cover on again. I have also not seen any ground saturation, heaving, cracking, dips, or any muddy areas anywhere near the pool. I have grass growing, finally, despite the drought. The concrete around my pool is also looking great (no heaving or heavy cracking where it should be).
So what can it be? Is it possible that I had/have two leaks in a brand new IG pool that has seen ONE season? Or could it be evaporation at the tune of a half inch a day considering that it has been relatively mild in NJ in October and now November (40-60 degrees with the last 4 or 5 days being over 70..yesterday was nearly 80).
If we understand what evaporation is... a different in temperature and pressure from water to air. If the water is frigid (40-50 degrees) and the air under the cover is hot as heck...plus a little but of air getting under the cover, could this cause enough evap?
I reached out to the guy who installed the cover and winterized to see if he does leak detection but I think I'll be hard pressed to get someone out here before it really does get cold. I think Im facing a situation of filling the pool throughout the winter as needed if there is indeed a leak or heavy evap (unless water temp/air temp under cover balances out better in the coming colder months).
Thoughts?
Thoughts?
