I have an older pool that was built in the late 80s. We bought the house last year and my kids loved it over the summer! From the beginning, I always noticed that Water seems to be dissipating from the pool faster than the expected 2 to 3 inches a from evaporation per week. As a solution, I simply put about 20 to 30 minutes of water in the pool each day as a temporary fix. Now that we are getting into the winter, I am starting to see the water level lower much faster. For example, during the past week, it lost over a foot with pump on the entire time. Today, I decided to do some closer investigation. One thing, I’ll Note, the water level, only seems to drop when the pump is on. Another thing I will note, is the pump always loses prime when it is not on for any long period of time.
Since we are in the middle of a drought right now, I decided to closely inspect the ground to look for damp spots. I noticed that my equipment pad was bone dry. I moved some leaves that were in front of the equipment pad and noticed that one spot, about 2 feet, was noticeably damper soil than the surrounding dirt that was dry.
While the pump was on, started to dig and found a small pipe and a large PVC pipe that seem to line up with the return on the equipment pad . The deeper I dug, the soil was slushy, and eventually when I got to the pipes, the hole started slowly filling with water, which definitely indicated to me that there is a leak.
I’m really hoping that I found the problem and that it is the only problem. Tomorrow, I am going to dig up everything around that area and investigate. Please let me know if anyone has any advice out there. Does anyone know what I can expect to find and how I will fix? If I stop this leak, could it also solve my prime issue from where it is at?
Attached are a few pictures of the wet spot I found in the hole that I dug. You can see where it lines up with the equipment pad. The small pipe sticking out of the ground on the equipment pad that is capped off appears to be the same type and diameter of one of the pipes underground near the leak. Does anyone know what this small pipe is for? The other pipe I see under ground is a larger diameter PVC that seems to match the return or suction pipes.
Any advice that anyone has would be great. Really hoping I found my problem. This will be much easier to solve than something under concrete slab, or even worse, a concrete pool.
The first picture shows the size of the damp spot on the ground. The other picture shows the hole I dug and pipes I uncovered.
I did notice that the water that rose in the hole did dissipate when I turned the pump off. This made me think the leak is function of the pump being on.
