Ah, OK. So Liquid chlorine.
If you want to minimize the amount of water you use, you would be best off lowering your CYA all in one shot.
So for example, if you wanted to go from 80 to 40 in a 30k pool, you would need to drain and add 15k total.
But if you did it 5% at time, you would need to drain and add about 20k total.
Ah, so that makes sense. And if you are getting rain, that is good too. If you can anticipate the rain, slightly better to empty before the rain and let the rain refill. vs overflow and then empty.
