laurandavid09 said:
I have the TF100 kit. I assume you mean the pink powder that comes in the white container.
My powder is white with a tinge of gray, but it turns the water pink, if that's what you meant.
laurandavid09 said:
The sellers left a testing kit behind when they left. The CYA tube in that kit is much smaller, which means I would use less chemicals than the one in the TF100 kit. Since that seems to be used a lot, can I use the smaller tube for the CYA test, as to be abel to use less of the chemical that comes in the TF100 kit?
With the CYA test the important part is to use equal amounts of test water and R-0013. After that, you just need to mix up enough total liquid to fill the tube far enough to get a good reading.
Curious, I thought the TF100 already used the small view tube!
laurandavid09 said:
I should be home earlier tomorrow during daylight still, so what test do I need to do tomorrow afternoon?
Daylight is really best for two things: color-matching (like the pH test) and the CYA test. For the CYA test, the optimal lighting is outdoors with your back to the sun. I'm not saying you should run it again; but if you happened to feel like it, that would be a good time.
At this point we know your pH is okay and your chlorine is low. So, you can just go ahead and put the bleach in (with the pump running). Give it, oh, an hour or so, until the sun's off the pool, then run the FAS-DPD test. Repeat the FAS-DPD test in the morning, preferably before the sun hits the pool. (This is the "overnight FC loss test.") If the morning test shows you've lost more than 1ppm FC, then you need to keep shocking.
laurandavid09 said:
Thanks. I am going to post some before pics of my pool of when I started and will post some pics of my progress now.
The pics are worth a thousand words. (You'd think I'd learn how to post some.
) Obviously much improved, with any luck you are near the end of the process.
--paulr
