laurandavid09 said:PaulR said:My powder is white with a tinge of gray, but it turns the water pink, if that's what you meant.laurandavid09 said:I have the TF100 kit. I assume you mean the pink powder that comes in the white container.
With the CYA test the important part is to use equal amounts of test water and R-0013. After that, you just need to mix up enough total liquid to fill the tube far enough to get a good reading.laurandavid09 said:The sellers left a testing kit behind when they left. The CYA tube in that kit is much smaller, which means I would use less chemicals than the one in the TF100 kit. Since that seems to be used a lot, can I use the smaller tube for the CYA test, as to be abel to use less of the chemical that comes in the TF100 kit?
Curious, I thought the TF100 already used the small view tube!
Daylight is really best for two things: color-matching (like the pH test) and the CYA test. For the CYA test, the optimal lighting is outdoors with your back to the sun. I'm not saying you should run it again; but if you happened to feel like it, that would be a good time.laurandavid09 said:I should be home earlier tomorrow during daylight still, so what test do I need to do tomorrow afternoon?
At this point we know your pH is okay and your chlorine is low. So, you can just go ahead and put the bleach in (with the pump running). Give it, oh, an hour or so, until the sun's off the pool, then run the FAS-DPD test. Repeat the FAS-DPD test in the morning, preferably before the sun hits the pool. (This is the "overnight FC loss test.") If the morning test shows you've lost more than 1ppm FC, then you need to keep shocking.
The pics are worth a thousand words. (You'd think I'd learn how to post some. ) Obviously much improved, with any luck you are near the end of the process.laurandavid09 said:Thanks. I am going to post some before pics of my pool of when I started and will post some pics of my progress now.
--paulr
Well the tube in the TF100 kit could be considered small, but the one in the other kits is about 1/3 the size. On that test tube I tend to get higher CYA.
So the main test I need to do tomorrow afternoon is the CYA Test. Find out what my CYA is and then use the chart to see what my shock FC needs to be. So should I do a FC test tomorrow as well to see where my FC is so that when I do the CYA test and find my shock FC, I can put in my FC test results as the beginning and my shock FC as the goal to get the right amount of bleach to add?
Hopefully that all makes sense.
I was reading the overnight fc loss test information in pool school. It says to test after I put in my last chemicals and do not add anymore chlorine and then test again in the morning. So when I do the CYA and FC test this afternoon, will I go ahead and add the bleach then or will I do the FC test this afternoon and again in the morning and then add bleach? It seems if I do the FC test after adding all the bleach, my FC will go very high, therefore requiring a lot of solution to do the FC test or am I wrong. Also when adding the bleach, how much should I add at a time and I assume in the deep end.
Thanks.
