I think zea3 has your ticket! I agree that if you find that your Overnight Free Chlorine Loss Test is successful (< 1 ppm loss) and the pool is just as clear as you want it... pat yourself on the back for putting this behind you and take a day of rest!laurandavid09 said:I need to bring my pool water level down some.
I think tomorrow my FC may not lose more than 1 ppm. My pool is pretty much clear now. I can see the bottom in the shallow and deep. I can even see the cover now at the deep end, which is the first time I have seen that.
So assuming my FC does not drop over 1 ppm, what will be the next steps I should take?
Check Chlorine, TA, pH, CH, CYA to see where you are at now. Adjust to recommended levels as per Pool Calculator. Then try to keep chlorine at the top of the daily range and test pH, TA, & CH weekly.
I hope you don't mind, but I turned a few questions back around to you. :-Dlaurandavid09 said:Here are a full test results
pH-7.5 (has held steady for a while now)
CL/BR-5/10 (I assume this has to do with shocking)
FC-12 (Becasue of shocking)
CC-.5
TX-12.5 (FC+CC I believe)
TA160 (Seems a little high, not sure if that has to do with shocking)
CH-220
CYA-30
Based off of these results, is there anything that I should do?
polyvue said:I hope you don't mind, but I turned a few questions back around to you. :-Dlaurandavid09 said:Here are a full test results
CC-.5
CH-220
CYA-30
pH-7.5 -- Test this again in a few days when the FC is lower... but it looks good now.
CL/BR-5/10 -- This is the OTO chlorine test and it isn't valid; the OTO test maxes out at 5 ppm but you know from your days spent shocking that FC is much higher. Why don't you forget about the OTO test next time? Just use FAS-DPD until FC is back in OTO's testing range 0-5 ppm.
FC-12 -- FAS-DPD test. What level should Free Chlorine (FC) be allowed to fall to? (How much chlorine do you want in your pool every day?)
TA160
CH-220
CYA-30
Do you have a SWG (Salt Water Chlorine Generator) on this pool?
Sorry if you've already answered this! Want to be sure I'm advising you correctly regarding CYA level.
Just from your experience so far ... days and days of testing ... What do you think we should do with these test results?
Good guesses, all. If using the Pool Calculator is in your comfort zone, just point your browser to http://www.poolcalculator.com/ and enter your test results, # pool gallons (top of page) and Suggest Goal Levels ("TroubleFreePool.com/bleach/plaster") - on the last row (bottom of page), then press the Calculate button.laurandavid09 said:I do not have a SWG. I think TA should come down some. Maybe CYA should go up some around 50. FC should be allowed to fall to around 4-5. Maybe increase CH to around 250-260. I just did the OTO test because it was in the same thing as the pH test.
I guess with the results I have, is it safe to swim I assume?
Good job!laurandavid09 said:I took a dip just to do it. I feel as if my work paid off. How often do you need to test CYA?
Regular schedule. If your water temperature is still warmer than 70 and you're still swimming, or planning to swim, you'll want to run the pump/filter so that it completes at least 1 turnover (~20K gallons) a day. Depending on your pump and system configuration that might mean just 3-4 hrs... or more than 8 hours.laurandavid09 said:Now that I got my pool under control, can I just run the pump during the day instead of the 24/7 I have been lately.
polyvue said:Regular schedule. If your water temperature is still warmer than 70 and you're still swimming, or planning to swim, you'll want to run the pump/filter so that it completes at least 1 turnover (~20K gallons) a day. Depending on your pump and system configuration that might mean just 3-4 hrs... or more than 8 hours.laurandavid09 said:Now that I got my pool under control, can I just run the pump during the day instead of the 24/7 I have been lately.
If/when the pool water temp falls below 60, you can reduce further; but keep up on your testing and a sharp eye on your water clarity....
