Jandy two port valve vs. ball valve
TadPool
9
Clermont, FL
CircuPool RJ-45 Plus
Can I use a Jandy 2 port diverter valve 4716 instead of the cheap ball valves? Do they work the same as far as controlling how much water flows through?
proavia
3,708
Chandler AZ
Yes and yes - and you won't have to replace them every few years like you would with the cheap ball valves either.
HermanTX
4,120
Katy TX
Jandy Aquapure 1400
The biggest advantage of the 2 way Jandy valve is that it is repairable without removing the body from the plumbing. A ball valve is not repairable but it is replaceable if you cut it out of the PVC plumbing and purchase a new one which also requires you to replace or modify your plumbing to accommodate it. the upfront extra cost of a Jandy 2 way valve is worth it considering the hassles you will have in the future with a simple ball valve.
markayash
4,221
Atlanta Ga
I used ball valves until I had one stick that required a complete redo on my plumbing after a year. Now I have Hayward and they came with unions so if one fails it’s easy to swap. I even bought a couple spares 😎
