I am considering buying a new SWG system and burning down my old one. Yet everything seems to be working. So frustrating.. I just replaced a Jandy 1400 Salt Cell Kit with flow sensor ,cable and cell. Im finding that something is wrong . It produces a low chlorine output(Almost like a 700 model). I never have experienced this before. I have to run my SWG on 100% all day just to keep up. Tops out at about 2.58 FC PPM. Cya ,salt levels , voltage tests within the Jandy control, and flow sensor all seem within normal range. Although the highest amp current on the cell is 5.85 amps. I don't know if that is ok. I read somewhere it was to be 7 amps.The amp current testing was done inside the control. Could the cell be defective?
Cya 48, salt 3300, Ph 7.5 (Ph dosing using a Cat ph controller). 6hr pump run time Taylor salinity test and with CYA ,FC and PH using Hanna reagent Colormeter. Don"t know were else to turn. Totally Frustrated....
