Jandy pump leaking
6XSBChamps
306
Longview, Tx
Not how I wanted to start the weekend. I can’t see where it’s coming out of but I assume these have a seal that goes?
After checking everything it seems the water is from under here. I assume there’s an O ring in there is I took them apart? I’ve never had to open them. I have been having problems this spring with debris getting through the basket and having to clear out the impeller. IMG_4131.jpeg
You need a go-kit which includes all the o-rings and seals.
Post up the model number of the pump here. And we'll help you find the right one.
If it were me, I would also order a US seals PS-1907 and use it for the shaft seal. Keep the one in the go kit as a backup. The SCS are much better shaft seals.
It is pricy, but after two standard seals in a year, I went with the SCS version and haven't had an issue in 4 years.
May be better prices.
Reactions: 6XSBChamps
