Long time listener - first time caller....
I've seen the same behavior with the same heater. I'm also stuck at step 3 of the troubleshooting guide.
Powers on and cycles each individual LED on - which is presumably a power-on-self-test. It's getting power, and getting the on signal from my pool controller. As OP noted, I've got 28V at the transformer - which is either normal because it's unloaded, or abnormal... and ?
My 10k thermister reads what i believe is right (10k at 72deg and 8.5kohm at 85 degrees water temp) and I've replaced the controller board. Behavior is the same. No voltage at the 3rd wire. Are there any alternative / external problems which aren't noted in the guice, but could prevent these contollers from deciding to come on?
Thanks.
Thanks.
