Hi All!
I'm new to this forum and new to inground salt water pools and heaters. I have had multiple above ground pools over the years, so I have some familiarity.
My family purchased a house this fall and moved into it in the winter. So my first experience with the pool and equipment was this week when opening the pool.
The pool was closed by a pool person, and said everything was working when it was winterized.
I got everything running with the pool, pump and salt generator with only some minor issues.
The major issue is with the Jandy Pool Heater.
I went to start my Jandy JXI Pool Heater, the first couple times I tried it, I had most things correct, but forgot to turn on the gas valve in the house, so the blower would turn on but would never actually ignite.
When I had the valve open, I turned on the heater again, the blower turned on and the heater seemed to ignite and started going for a minute. (There was now warm air coming from the exhaust). After a minute or two there was a loud bang and the blower stopped. I tried to turn it on again and the blower wont come back on at all anymore.
I went through the troubleshooting steps with my multimeter and all the wiring and electrical seem to be correct. The troubleshooting steps say that if all the electrical is correct, then replace the blower.
Based on this info: Would you all agree that I should replace the blower? Should I hire a pool heater repair person to replace it or can I do it myself? ( I found the part online)
I'm worried that I would spend $1000 on a new blower and there was some some other issue that led to the blower failing (the loud bang)
Thanks so much in advance!
