My pool company is telling me this is normal, but if so, it is a stupid design...
We have a new construction fiberglass pool with Jandy equipment including a VS pump and a Jandy JRT Series Heat Pump. The iAqualink RS board is the "Yg" revision. The heat pump is connected via the 4-wire automation connection.
The problem is that enabling the "Heat Pump" setting in the App sets the pump speed to 2750 and it never lets it go lower even when it reaches the set temperature. That makes it (even more) expensive to run the heater and means I have to manually disable the Heat Pump setting whenever it reaches temp.
The Heat Pump says it has a "Maintain Temp" function when connected via the 4-wire setup, but I'm not sure how that works and would mean that the Heat Pump is no longer controlled via the automation system.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
