Jandy iAqualink system pump speed stuck with Heat Pump enabled
dbetterton
15
Northern Maryland
My pool company is telling me this is normal, but if so, it is a stupid design...
We have a new construction fiberglass pool with Jandy equipment including a VS pump and a Jandy JRT Series Heat Pump. The iAqualink RS board is the "Yg" revision. The heat pump is connected via the 4-wire automation connection.
The problem is that enabling the "Heat Pump" setting in the App sets the pump speed to 2750 and it never lets it go lower even when it reaches the set temperature. That makes it (even more) expensive to run the heater and means I have to manually disable the Heat Pump setting whenever it reaches temp.
The Heat Pump says it has a "Maintain Temp" function when connected via the 4-wire setup, but I'm not sure how that works and would mean that the Heat Pump is no longer controlled via the automation system.
Any thoughts?
Thanks.
Yes, stupid design.
Since the Aqualink can only be updated by replacing the board Jandy has no easy way of improving what you have. Pentair and Hayward now have OTA (Over the Air) updates for their latest automation systems.
Your Aqualink system isn’t set up correctly. The heat pump heating is turned on and off by the Aqualink system as the water temperature changes.
While I don’t have a heat pump I have a Laars/Jandy LX gas heater that is connected to the Aqualink via the four wire RS-485. If your VSP speed settings are set up correctly you should have a speed associated with the heat pump (aka pool heat function).
I can have the Gas heater on and when firing the VSP pump speed increases to the speed associated with either Pool Heat, or Spa heat, whichever is enabled.
As soon at the water reaches temperature the VSP pump speed falls back to the filter/pump speed setting, or the spa speed setting if the spa is enabled.
I suspect that your VSP speed settings are not correct. Show us this VSP setup page in your Aqualink setup menu pages:
Sorry, I missed this post. This is what shows up (I have to cycle through to "Pump 5" to see the settings).
The pump does change to the Heat Pump speed when the "Heat Pump" toggle is enabled in the app.
Your problem is that you have renamed almost all of the VSP Speed Labels. On the Jandy RS system almost all of the speeds are hard coded to a function regardless of what you name the speed label.
With most systems only speed labels 7 and 8 are unused and available for renaming and using unrestricted. In some cases the cleaner and spillover speeds can be reassigned if those functions are disabled.
If your heat pump is your primary (only) heater then its pump speed will be defined by the pool heat, and spa heat speed labels as it is considered “the heater”.
Defining a speed label Heat Pump causes the Jandy system to treat the heat pump as a function rather than a heater so any time the function is on the pump runs that speed.
First off change the VSP speed labels for the first 6 speeds to match mine (as shown earlier in this thread) as those are the default labels and those functions are hard coded and that is what the system does regardless of the names.
You can rename and assign speeds 7 and 8 as you like, but don’t use heat pump.
The Dip switches should be set up so that your system knows that the heat pump is your “heater” and as such the pool heat and spa heat speed labels will control the “while firing” pump speeds. “pool heat” and “spa heat” are the functions used to enable the heat pump with the set points of “pool temp” and “spa temp”.
The “pool” and “spa” speeds are the speeds the pump runs when the heater isn’t actually firing, like after the temp has been reached.
The other thing to note is that the fastest speed always wins when multiple speeds (or functions) are active.
First off change all your speed labels back to the defaults and get rid of the heat pump speed label. Set the speeds you want for the label names accordingly.
It’s very possible that your heat pump isn’t properly configured to be the “heater” in the system, and we can fix that also (by setting the dip switches correctly) but please get the speed labels fixed first.
Thank you!
I know that the dip switches are not set correctly - was told by the pool company that they "aren't used" with the automation. That didn't seem correct, but first time pool owner, so I have been hesitant to change things.
I'll pull out my manual later and confirm the dip switches I should change. I'm trying to enjoy the pool before it starts storming here. :)
EDIT TO ADD: Does it matter that I don't have a separate spa? We have a tanning ledge, but it simply overflows into the main pool - so it is effectively one body of water. The pool company got the pool and spa combo board because it came with the two automatic valves that are used for the tanning ledge return and the bubbler in the tanning ledge.
So confirm I should change the following dip switches to On - everything is set to Off right now.
S1 DIP #7 which is described as "Not Used" but the manual also says "When ON the pool and spa share the same heater"
S1 DIP #8 Heat Pump instead of gas
S2 DIP #1 Heat Pump priority (instead of solar which I don't have)
Since your heat pump is connected by the RS-485 interface I think you only need to set S1 DIP switch 8 to on as that tells the system that you have a heat pump instead of a gas heater,
S1 switch 7 is only used for dual equipment systems (separate pumps and heaters for two bodies of water) so that should stay off.
S2 switch 1 can stay off also. Heat pump priority is used when hooking the heat pump up to the solar relay contacts (you have the RS-485 interface) and also used when you have both a gas heater and a heat pump. The priority setting uses the heat pump to maintain the temp before the gas heater (I believe, not completely sure of this).
Once you tell the system that you have a heat pump instead of a gas heater with S1-8 on then the heat pump should be enabled any time you enable "Pool Heat" or "Spa Heat". Think of the Pool heat and Spa Heat labels as two separate temperature set points, with pool heat being lower than spa heat.
When set up right with the pump on (filter/pump function on) the pump will run at Pool speed. When you also enable Pool heat (or Spa heat) you will be enabling the heat pump with the respective temperature set points. When the heat pump is actually heating the pump speed will increase to the pool heat (or spa heat) speed setting. As soon as the water reaches temperature and the heat pump shuts off then the pump speed will drop back to pool speed.
It sounds like your Spa function is just used to redirect water to you shelf and bubblers, if you need to run the pump faster for that then you can change the speed setting for spa. The two heat settings are just that, two different temperatures and are not specifically linked to the spa or pool functions.
I think you will be okay by just setting S1-8 to on, then you can use pool heat and spa heat functions to enable the heat pump. You also need to change all the VSP speed labels back to their defaults and get rid of the heat pump label. Then just set your speeds accordingly remembering that the fastest speed always takes priority.
So your pool speed that is associated with filter/pump wants to the the slowest speed you ever want to run and pool heat / spa heat want to be faster. That way the speed increases when the heat pump is running, and then drops back down to a lower speed when it turns off.
Here is some more information on how the RS system handles VSP speed settings:
Reactions: dbetterton
Another thing, lets make sure that your Aqualink RS system is actually connected to the RS-485 interface on your heat pump. From the home of Aqualink web interface page click the help button on opening screen. Then click next twice and you will see a list of the RS-485 controlled devices. You should see your pump, the aqualink WiFi unit, and your heat pump there. Here is what that page looks like on my system:
D better did following these instructions make any improvement to your system? I have a very similar concern with my system and my builder/installer said that I should ignore the "Pool Heat" and "Spa Heat" toggles since they "are if you have a gas heater".
When I enable the Heat Pump toggle it automatically sets the pump to speed 7 regardless of the label.
I think actually this setup might work, I believe speed 7 should be set to the minimum speed required for flow through the heater(which in my case is probably close to the "pool" speed) then I can use the"pool heat" (speed 5) to ramp up which the heater is heating. Once temp is reached it will say "standby" next to both heat pump and pool heater and will fall back to the "heat pump" speed.
Same for Spa Heat just that my spa mode also isolates the spa from the pool.
Just to update for anyone actually still reading this thread;
I moved S1 DIP #8 to "Heat Pump" it was in the "Off" Position which according to the manual is "Gas Heater" However, this did NOT change the operation of the system. Here is how it currently operates;
If I enable "Heat Pump" It will automatically set my Pump5 (VSP) to speed 7 (regardless of Label)
If I enable "Pool Heat" (and the temperature Triggers "Heating") It will switch the speed to the higher of the two settings (Heat Pump or Pool Heat)
When the Temperature Triggers "Standby" Mode, the System will fall back to Speed 7 (Assuming "Heat Pump" is still enabled).
So This is how I'm currently Configured;
And these are my Current Schedules;
So with this setup, and Assuming I leave my Heat Pump Enabled and the Pool Heater Enabled I expect the following Behavior (Not fully tested):
If the Pool is Above the Heat Pump Set Point:
Pump will Turn on at ~8am and run in "Heat Pump" Mode (1750 RPM)
Pump Will Switch to Floor System Speed (3450) ~8am
Pump Will Switch Back to "Heat Pump" Speed ~ 9am **It doesn't switch back to pool because Heat Pump is enabled. I'm leaving the Pool Speed in there for when my heat pump isn't enabled
Pump will Switch to Floor System Speed (3450) ~12pm
Pump Will Switch Back to "Heat Pump" Speed ~ 1pm
Pump will Switch to Floor System Speed (3450) ~6pm
Pump Will Switch Back to "Heat Pump" Speed ~ 7pm
Pump Will Turn off at ~8:01pm
**If the Pump is Off, and the Heat Pump is Enabled, It Stays in Standby Mode (since it has no temp) and does not automatically turn the pump on (this is good for me)
If at any point the temperature drops below the Heat Pump Set Point, the Pump SHOULD swap to the highest RPM Setting for the time period;
If Heating Turns on During a Heat Pump Speed, the Pump will switch to "Pool Heat" Speed
If Heat Turns on During a Floor System Speed, the Pump Should Stay in 3450 and drop to "Pool Heat" when Floor System Speed Time is Done.
Something to Note is that the "Pool Heater" Toggle Does not actually change the way the Heat Pump Works all it does is change the Pump Speed in my Case (since I have it set different to "Heat Pump"). If the Heat Pump is enabled it will go into Heat Mode or Standby Mode REGARDLESS if Pool Heater is enabled or not, but it will keep the pump in "Heat Pump" speed for both Standby and Heating Modes (or if I have a higher speed scheduled).
At least these are my Findings.
