Hello all,
I have learned so much reading this group. Thank you all.
I have a problem where when the RS is in auto mode the iaqualink shows "Waiting for Connection". Thinking this was an issue with the iaqualink AGAIN, second unit in 5 years. I decided to do a DIY installation instead. Found this raspberry pi software Error: Aqualink daemon looks like serial error, resetting. · Issue #34 · sfeakes/AqualinkD · GitHub which allows you to have the same functions as an iaqualink for about $50 in parts & a few hours of nerd time to get it running. Got it all set up and the same thing. Nothing on Auto mode.
So with this software, I can see the reporting of accurate data (IE: Pump running, ect... ) when the unit is in service mode. However when I put the unit in Auto mode nothing.
Here is what's interesting. When your on a raspberry pi running this command below SHOULD show the output below. However, it shows nothing. However if in service mode it does. So the problem is ONLY on the auto mode, has nothing to do with the iaqualink.
I also tried replacing the PCB and got the same issue. Anyone here have an idea?
sudo -s eval 'stty raw -echo < /dev/ttyUSB0; cat -vte /dev/ttyUSB0'
That should give you lots of junk and a few words, like below
^C^@JANDY AquaLinkRSp^P^C^@^P^B^@^A^@^@^S^P^C^@^P^B*^@<^P^C^P^B^H^B^@^@^@^@^@^\^P^C^@^P^B^@^A^@^@^S^P^C^P^B$
^B^@^@^@^@^@^^^P^C^@^P^B^@^A^@^@^S^P^C^@^P^B`^@r^P^C^P^B^H^B^@^@^@^@^@^\^P^C^@^P^B^@^A^@^@^S^P^C^P^B$
^B^@^@^@^@^@^^^P^C^@^P^B^@^A^@^@^S^P^C^@^P^B+^@=^P^C^P^B^H^B^@^@^@^@^@^\^P^C^@^P^B^@^A^@^@^S^P^C^P^B$
^B^@^@^@^@^@^^^P^C^@^P^B^@^A^@^@^S^P^C^@^P^B`^@r^P^C^P^B^H^B^@^@^@^@^@^\^P^C^@^P^B^@^A^@^@^S^P^C^P^B^H^C^@ AIR TEMP 87M-_F c^P^C^@^P^B^@^A^@^@^S^P^C^P^B$
^B^@^@^@^@^@^^^P^C^@^P^B^@^A^@^@^S^P^C^@^P^B8^@J^P^C^P^B^H^B^@^@^@^@^@^\^P^C^@^P^B^@^A^@^@^S^P^C^P^B$
If you get this far, things are looking good. Go to installing AqualinkD.
