I’m experiencing issues with my 3 HP Calimar Pump, which has an Automation Adapter installed. I’m trying to operate the pump at two speeds: 3000 RPM (controlled by the black wire) and 1500 RPM (controlled by the white wire), as per the instructions.
The problem is that I can only get the pump to start at either 3000 RPM or 1500 RPM, but I can’t seem to switch between the two speeds. It’s possible that I’m not supplying power to Aux7 correctly, or there may be another issue. I’ve run a wire from my filter pump relay to the bottom left connection of the Aux7 relay, but I’m still encountering the same problem. The pump starts and stays at the same RPM I start it with.
Any advice on troubleshooting or wiring adjustments would be greatly appreciated! I know there are a couple of you on here with a similar setup. Thanks,
