With my electric rates expected to skyrocket once my contract runs out early next year, I've fast-tracked my plans to upgrade my main filter pump to a variable-speed unit. I currently have a single-speed 1.5 hp pump controlled by a Jandy iAqualink 2.0 system (other details of my system as described in signature). I have no interest in shelling out $1500-2000 for a Jandy VS pump, so I'm looking at inexpensive third party options. Would the following approach make sense?
- Replace main pump with Calimar 3.0 hp VS Pump
- Install B+D Automation-Capable Variable Speed pump adapter on the pump (assuming that this works with nearly-identical Calimar pump...does anyone know if this has been verified?)
- Rewire the iAqualink panel as follows (see attached images):
- Hardwire VS pump to 240v power (ie pump power is no longer controlled by relay, pump is always on, except when its breaker is off)
- Use current Filter Pump relay to control pump Speed 1 (~600-1000 rpm, run ~16 hours a day)
- Add new relay for Speed 2 (medium speed, used when operating heater or booster pump)
- (Optional) and second new relay for Speed 3 (high speed, used for max suction when manually vacuuming pool)
- Program iAqualink as follows:
- Speed 1 relay is engaged ~16 hours a day
- Speed 2 relay is engaged ~2 hours in the morning, ~2 hours in afternoon to assist with skimming of the pool (booster pump on for 2 hours during the afternoon Speed 2 block)
- Speed 2 is also engaged whenever OneTouch commands to heat the pool or spa are selected (ie whenever the heater is running)
- Speed 3 is engaged manually when I'm vacuuming the pool
