Is this a DIY repair?
PaigeMark
168
Tulsa, OK
Some of the sealant between my travertine tile deck and the backside of the pool coping was missing or coming loose so I was in the process of digging it out when I found a few loose coping tiles. They were loose enough for me to lift them out of place and see that the metal brace for the scupper tile has badly corroded. Do I need to call a pro or is this within the DIY arena for someone with some fix it skills? Any idea what to do about that metal brace?
I’m thinking I chip off or grind off the old grout and mortar, let it dry out well and then attach the brace and tiles in some sort of mortar/adhesive? Grout, then seal? Is it a lot more complicated than that?
Thanks so much for your help.
ajw22
27,953
Northern NJ
Pentair Intellichlor IC-60
Just cleanup the metal brace and coat it with rust neutralizer.
Use type S mortar to reattach the stone. With the small area on both sides of the stone it will probably come loose again. That area is a poor design.
PaigeMark
168
Tulsa, OK
Thank you! Agreed. It is a poor design and is repeated on the other pool wall at the second skimmer. Wire brushed & scraped the flaking rust off of the metal brace and sprayed it well with rust neutralizer. Cleaned off the rust residue off of the pool tiles. Type S mortar to set the stone and now I’m waiting for it to set before adding grout. I will also be using a self-leveling sealant (Sika) for the gap between the deck tiles and the coping. I appreciate your help.
