- Jun 4, 2007
- 255
- Fiberglass
- Pentair Intellichlor IC-40
Wow, this thread is different! Can't wait to see what happens....
The happiness this brings me is not measurable. I was miserable and clueless seeking guidance on from high schoolers working at the pool store. Wish I had found TFP so much sooner.
Speaking of........ wanna know how I landed here ? I wad told to acid bath my SWG for 15 mins at the middle and end of the season. It soaked for 3.25 hours in straight acid over its lifespan and died with 6k hours showing. I learned on day 2 how to check it and why it likely died.Wish I had found TFP so much sooner.
That must have been terrifying!!That pool store's advice ruined my linerMy CYA and pH/TA were SO wrong my liner "dry rotted" with water in it
My toe found something on the bottom of the liner one afternoon. I played with it and the whole bottom of my liner started cracking open!! I made it to the side of the pool just before all 25,600 gallons of water rushed out. THAT was when I found TFP!
It will have worked when the phosphate test shows it worked. If it’s clear it’s a good time to test.Pool has all but cleared from the cloudiness this morning and filter is at 22 PSI. Probably will backwash and add back DE later this morning.
At what point would we consider phosphate treatment “complete” and want to try and reboot the SWG? I was thinking after todays backwash we give it another full day of filtering to see where the pressure reading is at and if we need another backwash.
Thoughts?
So!! Here is the kicker…I do not have a phosphate test. I feel like this experiment all came together pretty quickly and when we addressed “should I get my own phosphate test?” earlier in the thread, we weren’t there yet or even sure if I was gonna go through with it. I guess we should have revisited this topic but alas…It will have worked when the phosphate test shows it worked. If it’s clear it’s a good time to test.
So, since we started with pool store numbers, should I just take a sample back to the pool store to evaluate results?
Sounds like a good plan.Morning update:
Water was clear and filter showed PSI of 22 so I backwashed. That was quite the experience! I thought the sight glass would never clear and actually stopped at one point to redirect my hose. Once that was complete, went back to filter mode and added DE through skimmer. PSI is now at it’s usual 14 and will monitor that regularly.
I lost a good bit of water so have the garden hose in the pool now.
FC this morning is 10. Once I get my water level back up and it mixes in a bit, I’ll test the water again for CYA and salt, then head to the ((cringe…gulp)) pool store ((shivers)) to see what the phosphate reading is.
Really hoping as soon as I post this someone hasn’t responded with suggestion to do something entirely different haha.
PhewSounds like a good plan.
So, since we started with pool store numbers, should I just take a sample back to the pool store to evaluate results? I know…the horror.
